Bri-Guy-GA Posted August 12, 2012 Report Posted August 12, 2012 (edited) I just replaced my water pump and lower hose after the car running hot. It seems to run within normal parameters now, but I noticed after a 20 minute drive that the lower radiator hose has collapsed. What could cause this? I replaced the thermostat several month back so that is unlikely the cause. I did notice that when i opened the bleed valve at the thermostat the hose went right back to shape. Also when it overheated when the hose blew the overflow tank was full. Ideas? Edited August 12, 2012 by Bri-Guy-GA Quote
Schurkey Posted August 12, 2012 Report Posted August 12, 2012 I just replaced my water pump and lower hose after the car running hot. It seems to run within normal parameters now, but I noticed after a 20 minute drive that the lower radiator hose has collapsed. What could cause this? I replaced the thermostat several month back so that is unlikely the cause. I did notice that when i opened the bleed valve at the thermostat the hose went right back to shape. Also when it overheated when the hose blew the overflow tank was full. Ideas? 1. Defective radiator cap. 2. Pinched hose between rad cap and overflow bottle, especially if hose collapses after engine is shut down. 3. Soft and defective lower rad hose, especially if it only collapses when the engine is at high RPM. Quote
chrisflstf Posted August 17, 2012 Report Posted August 17, 2012 You have air in the system and it needs bled Quote
Bri-Guy-GA Posted August 21, 2012 Author Report Posted August 21, 2012 Replaced the cap and everything is back to normal. Quote
