Arite so 3 months ago I did my front end on the cutty...I replaced the struts...coil seats...ball joints and brakes...everything was fine until now...the drivers wheel bearing is growling and my springs are popping every time I park the car.Does anyone know what I did wrong? Im pretty sure I didn't sit the spring properly but I'm not sure. Is this fixable? Do i just redo everything?
As always Thanks in advance for any help
Did you reinstall the thick washer behind the CV axle nut if you had that apart?
