GTP091 Posted December 2, 2020 Author Report Posted December 2, 2020 Need to figure out parts plan for this engine build now that I’m back into it. The haggerty guys seem to like Fel-Pro a lot. The other brand im wondering on is engine tech. They have a complete rebuild kit on rock auto that is interesting. Would like to be sure I get the better of the two. Anyone who’s done an engine rebuild have any preference? Also need some ideas on pistons/rings/journal bearings etc. Can’t order yet as I need to see what kind of machining is needed first just want an idea. Quote
carkhz316 Posted November 12, 2021 Report Posted November 12, 2021 How is this project coming along? I've been binging anything 284-related to try and learn more as I head into the back stretch of my LS4 swap. Quote
55trucker Posted November 12, 2021 Report Posted November 12, 2021 1 hour ago, carkhz316 said: How is this project coming along? I've been binging anything 284-related to try and learn more as I head into the back stretch of my LS4 swap. Food for thought: the 284 is rated for 250ft.lbs of torque, the LS4 is a 320 ft.lbs torque engine, I personally would choose the F40 trans to go behind the LS4. It's a certified 300 ft.lbs trans, the idea of exploding an already *hard-to-find-parts* piece doesn't really appeal to me. Quote
Bake82 Posted November 12, 2021 Report Posted November 12, 2021 1 hour ago, 55trucker said: Food for thought: the 284 is rated for 250ft.lbs of torque, the LS4 is a 320 ft.lbs torque engine, I personally would choose the F40 trans to go behind the LS4. It's a certified 300 ft.lbs trans, the idea of exploding an already *hard-to-find-parts* piece doesn't really appeal to me. Many 3800 guys have put down 400whp up to 800whp through a getrag 284. He shouldn't have any issues behind his cammed LS4. carkhz316 1 Quote
carkhz316 Posted November 13, 2021 Report Posted November 13, 2021 (edited) 11 hours ago, 55trucker said: Food for thought: the 284 is rated for 250ft.lbs of torque, the LS4 is a 320 ft.lbs torque engine, I personally would choose the F40 trans to go behind the LS4. It's a certified 300 ft.lbs trans, the idea of exploding an already *hard-to-find-parts* piece doesn't really appeal to me. While the ratings are underwhelming, the 284 has been proven to handle a magnitude of power beyond what it was advertised and intended to. Believe me, the whole "unobtanium" aspect of this transmission is frustrating, but it doesn't matter since they break in stock applications too. Yes, throwing more power at it isn't going to help things, but I've accepted that this was a one-way street when I swapped transmissions originally. Additionally, I have two more (3 total) to work with, so I'll be alright for awhile. Edited November 13, 2021 by carkhz316 Quote
GTP091 Posted November 14, 2021 Author Report Posted November 14, 2021 On 11/12/2021 at 6:01 AM, carkhz316 said: How is this project coming along? I've been binging anything 284-related to try and learn more as I head into the back stretch of my LS4 swap. I’ve got two 284s sitting on the bench now. One is needing a ‘rebuild’ lol or exploratory surgery to see how they come apart and never go back together again. I haven’t quite got the engine rebuilt yet that is going to go together with the good 284 I have. The rebuild should be finished up by spring. Need to source out a good cradle yet. carkhz316 and pwmin 2 Quote
GTP091 Posted July 4, 2023 Author Report Posted July 4, 2023 Finally sourced a set of new hydraulic lifters for the engine rebuild. Engine tech and a Timing chain set. pwmin, jiggity76 and jman093 3 Quote
SuperBuick Posted September 22, 2024 Report Posted September 22, 2024 On 7/4/2023 at 3:38 PM, GTP091 said: Finally sourced a set of new hydraulic lifters for the engine rebuild. Engine tech and a Timing chain set. Bringing this topic back to the top. So much useful searchable info here, so much better than facebook @GTP091 how is your swap going? @White93z34 @55trucker do you guys know if the getrag 282 transmission mount (part Pioneer 622620 ) will work on the 284? On my car which is a factory 284 car, there is also this circle black plastic thing on the bottom that looks like a mini hockey puck… thats all cracked up and needs repair/replacement. The transmission case has a rubber vent looking thing on top (almost like a shark fin but which air flows through) - does a 282 have that also? Mine is all ruined - not sure what it does or if its needed. I will post pics when I get back home. I have many more questions on the “manual swap” because in order to convert my Satanic / Powermaster brake system to normal brakes, I basically have to undergo the same work with regards to the firewall plate - and that seems to be the hardest and least documented part of the job. I will have one powermaster brakes/manual firewall plate, and another vaccum brakes/automatic firewall plate to work with. Quote
Bake82 Posted September 25, 2024 Report Posted September 25, 2024 On 9/22/2024 at 10:07 AM, SuperBuick said: Bringing this topic back to the top. So much useful searchable info here, so much better than facebook @GTP091 how is your swap going? @White93z34 @55trucker do you guys know if the getrag 282 transmission mount (part Pioneer 622620 ) will work on the 284? On my car which is a factory 284 car, there is also this circle black plastic thing on the bottom that looks like a mini hockey puck… thats all cracked up and needs repair/replacement. The transmission case has a rubber vent looking thing on top (almost like a shark fin but which air flows through) - does a 282 have that also? Mine is all ruined - not sure what it does or if its needed. I will post pics when I get back home. I have many more questions on the “manual swap” because in order to convert my Satanic / Powermaster brake system to normal brakes, I basically have to undergo the same work with regards to the firewall plate - and that seems to be the hardest and least documented part of the job. I will have one powermaster brakes/manual firewall plate, and another vaccum brakes/automatic firewall plate to work with. A 282 mount will work with a 284. It’s slightly different but has been done in the past. post a pic of the 284 rubber piece. I’ll have a look at my 282 for comparison. Quote
SuperBuick Posted September 25, 2024 Report Posted September 25, 2024 40 minutes ago, Bake82 said: A 282 mount will work with a 284. It’s slightly different but has been done in the past. post a pic of the 284 rubber piece. I’ll have a look at my 282 for comparison. Awesome - I will post in the am! Quote
SuperBuick Posted October 7, 2024 Report Posted October 7, 2024 On 9/25/2024 at 12:19 AM, SuperBuick said: Awesome - I will post in the am! This is the “shark fin” piece… Quote
55trucker Posted October 7, 2024 Report Posted October 7, 2024 That rubber shield covers the air inlet port for the clutch housing. SuperBuick 1 Quote
SuperBuick Posted October 9, 2024 Report Posted October 9, 2024 On 9/24/2024 at 11:39 PM, Bake82 said: A 282 mount will work with a 284. It’s slightly different but has been done in the past. post a pic of the 284 rubber piece. I’ll have a look at my 282 for comparison. So I bought the 282 mount and I can see absolutely no way to make it work on the 284. The 284 mount has bolts that go through it and mount into the side of the transmission, with studs down and into the cradle. The 282 mount has studs up into the bottom of the transmission, and studs down into the cradle... Quote
Bake82 Posted October 10, 2024 Report Posted October 10, 2024 15 hours ago, SuperBuick said: So I bought the 282 mount and I can see absolutely no way to make it work on the 284. The 284 mount has bolts that go through it and mount into the side of the transmission, with studs down and into the cradle. The 282 mount has studs up into the bottom of the transmission, and studs down into the cradle... Sounds like you got an auto mount instead of a manual trans mount. Viewing rockauto the olds cutlass manual mount shows an auto mount under the manual trans option. I found the right ones under a 89 Grand Prix. Screenshot below. SuperBuick 1 Quote
