I've got no heat in my 95 Grand Prix with the 3100. So far we've replaced the heater core and made sure all of the doors are opening and closing. The only thing I can think of is we have the hoses messed up. I need to know which pipe on the heater core on the firewall is the feed and which one is the return. The feed for the heater core comes from the black pipe that comes off the water pump housing right??
Thanks
Mike
not sure about the 3100, but for the 3.4, the inlet hose comes from intake area whereas the water pump hose is the heater core outlet
There could be an air pocket caused by a lac of coolant which would cause no heat.
Blower works just blows out cold to luke-warm air. Coolant system is full and has been bled multiple times.
Thanks for any more help
Mike
I've got no heat
You probably already thought of it, but did you replace the thermostat?
i had the same problem in mine and it was the thermostat.
however, no heat is a good way to stay awake on those late-night drives during the winter :?
deef
Check to see if your Cruise Control works or not. Cruise Control and the Cold/Heat selector is tied together by a vacuum line.
Cruise works. Thermostat has been replaced and it seems to work. Car runs right were it should at about 190. This thing has got me stumped. I had the heater core lines off and blew air through them. Some of the Bars Stop Leak that I had before came out. Now I know I'm getting flow through the heater core, but maybe it's still plugged?? The heat got hotter after doing this.
Thanks
Mike
