Justin Webb Posted July 18, 2012 Report Posted July 18, 2012 I have a 94 grand prix se and i can not get it to start.at first it would just click a few times but now it does nothing.when i turn the key i hear a eird sound coming from around the glove box.could it be the Anti-Theft Relay?Or could it be a starter relay.If it is a starter relay where in the heck is it at? Thank you Quote
Justin Webb Posted July 18, 2012 Author Report Posted July 18, 2012 No battery is fully charged.Just the buzzing sound when i turn the key..all the lights work,but when i turn the key to try and start the car the lights do not dim at all...Should'nt then dim a bit when trying to start it? Quote
rockfangd Posted July 18, 2012 Report Posted July 18, 2012 not necessarily. Get an actual voltage reading somewhere to verify you have good connection at the battery. I usually check at the alternator and engine for good 12v. Side terminal can be hard to tell when you have a bad connection Quote
Justin Webb Posted July 18, 2012 Author Report Posted July 18, 2012 I can get the car to start if i jump the solenoid.starts right up.for some reason it is not getting any power from the start to the ignition switch...thats why i think it might be a bad relay.but i cant find the relay to the starter. Quote
Justin Webb Posted July 18, 2012 Author Report Posted July 18, 2012 Ok found the problem.it's a short in the steering column somewhere.If i wiggle the steering wheel back and forth it starts right up. Quote
mhildebrand Posted July 18, 2012 Report Posted July 18, 2012 It could also be the ignition switch itself. I replaced one in a Cavalier last week, and it did the same thing. Quote
