Rear Window Trim cracked!!
Just wondering can it be changed,it's all cracked and out of place,I have more on a parts car that I can replace it with,but can it be pulled off?Any info would help...thanks.
Mine was wrecked on my Cutlass and I pulled it off. Its held in by plastic clips.
I bought a new GM one for my car and it was like $50.
I wonder does it slide or do you pull it out?I imagine it would be hard to get it off a scrapped GP...which I was planning to do.
I have the same problem with my cutlass
the drivers rear window trim is cracked at the bottom
there are clips holding it on?
what direction do you slide it to remove it from these clips?
thanks
dave
For the top panel along the window:
Unbolt the black metal panel that goes up to the roof (actually screws).
Theres a screw that holds the molding on at the top of where the panel was. Unscrew it and then peel the molding up with a small screw driver. The clips are between the glass and roof and theres tabs built into the molding.
For the bottom one:
Undo the black panel and theres a screw at the bottom and then undo it from the clips the same way.
