Interchangeable Transmissions? Looking for a compatible replacement
you SHOULD be able to swap any ~94-99 W-body 4T60E(with the 94 3.1 luminas being an exception) between each other and only have to deal with a potentially different FDR or maybe VSS pulse ring having a different number of notches. electrically, they should be more or less be identical, to the point of not needing to repin/replace anything other some cars needing specific PRNDL switches.
  • 1 month later...
Does anyone have PINout for the 4T60e Trans connector for 95 & 96? i'm trying to figure out what is the difference. Now that i'm running the 95 trans with the 96 System.
a 95 and 96 4T60E should have the exact same connector pinout, regardless of 3100/3.4/3.8....
