ricklovin93 Posted June 30, 2012 Report Posted June 30, 2012 Just wondering if anyone has used a standalone management system I was reading about em was i just brainstorming some ideas Quote
z34Phoenix Posted July 1, 2012 Report Posted July 1, 2012 not many people have gone stand alone. Most retune the factory pcm. the abilities in the factory unit have more then enough functionality to handle the majority of the setups run. Quote
RobertISaar Posted July 1, 2012 Report Posted July 1, 2012 the ECM i'm running for the 91 isn't quite factory, but it's not standalone either.... somewhere in between. Quote
ricklovin93 Posted July 1, 2012 Author Report Posted July 1, 2012 the ECM i'm running for the 91 isn't quite factory, but it's not standalone either.... somewhere in between. Please do explain rob Quote
RobertISaar Posted July 1, 2012 Report Posted July 1, 2012 it's a 91-93 LQ1 PCM(16149396) with some significant internal modifications.... extra A/D channels, extra inputs, extra outputs, extra addressing space.... fun stuff. Quote
ricklovin93 Posted July 1, 2012 Author Report Posted July 1, 2012 What's easier to tune obd 1 or 2 Quote
RobertISaar Posted July 1, 2012 Report Posted July 1, 2012 depends on what you get exposed to first. they function similarly in that you're always attempting to give the engine what it likes, but each system has it's advantages and disadvantages. Quote
ricklovin93 Posted July 1, 2012 Author Report Posted July 1, 2012 I wanna try an obd1 car due to the easier emissions testing I'm afraid that with an obd2 car any tuning done can set off dtc codes and cause me to fail inspection. But with an obd1 car there's no worry. About it Quote
WhatTheFehl Posted July 1, 2012 Report Posted July 1, 2012 It would appear OBD2 has more functionality, and there is much more current support. If you really want to get technical, you can just tune out a DTC so you don't fail emissions... Quote
ricklovin93 Posted July 1, 2012 Author Report Posted July 1, 2012 Inspection computers can see if a dtc code is erased and then fail you Quote
RobertISaar Posted July 1, 2012 Report Posted July 1, 2012 It would appear OBD2 has more functionality, and there is much more current support. not necessarily. i believe you're referring to the setting certain tests/DTCs to "always pass/already completed". Quote
WhatTheFehl Posted July 1, 2012 Report Posted July 1, 2012 Inspection computers can see if a dtc code is erased and then fail you Not necessarily... depends on how it is tuned. But... Quote
