GP1138 Posted June 30, 2012 Report Posted June 30, 2012 Doing an inspection on a squeaky serpentine belt the other day, and I noticed this: The other side is decidedly NOT misaligned as this seems to be. I remember this being a little less cocked to the upper right. What exactly might have happened here and how difficult is it to do a front strut job on this car? Quote
AL Posted June 30, 2012 Report Posted June 30, 2012 If all the bolt holes line up, I wouldnt worry about it Quote
Crazy K Posted June 30, 2012 Report Posted June 30, 2012 you might investigate the cost of new "loaded" front struts, I get the vague impression that top mount is wearing out due to rust through, and a loaded unit will have a fresh mount. OR just the cost of the top plate, only... Quote
runt Posted July 1, 2012 Report Posted July 1, 2012 You can buy new Quick Struts for those cars for about $135/ea. I believe that the quick strut is the same as Ken saying "loaded". Quote
Schurkey Posted July 1, 2012 Report Posted July 1, 2012 And don't forget to put a proper end on that wire, and clean the metal it's grounded to. Quote
Andrew Posted July 1, 2012 Report Posted July 1, 2012 struts on these cars are super easy. those 3 nuts on top and 2 bolts at the bottom, and its out. if its not making noise, i wouldnt worry. Quote
Crazy K Posted July 6, 2012 Report Posted July 6, 2012 quick thought: with teh car in park and the hood open, rock the car and make sure that it isn't shifting. if it isn't, It's probably fine. Quote
