daughters car Posted June 28, 2012 Report Posted June 28, 2012 GM no longer makes the rear suspension support for the 1998 lumina. Are there any other years or other GM cars that this part is interchangible? Daughtes car is in pieces in the driveway, need this part. Junk yards have very rusty parts, trading a really bad part for a bad part. Any suggestions? Thanks Quote
wickedbuick Posted June 28, 2012 Report Posted June 28, 2012 I may need corrected but I believe any 95-2001 Lumina should have the same support, as well as any 95-99 Monte Carlo Quote
wickedbuick Posted June 28, 2012 Report Posted June 28, 2012 I looked at some places that sell GM parts and it seems they didn't have any in stock since discontinued as you said but sold for $256. I'd look for a 2001 lumina in the junk yard for that part if you can. I did look and that is the same for all the years I listed above. Good luck! Quote
Cutlass350 Posted June 28, 2012 Report Posted June 28, 2012 (edited) The site http://car-part.com/ uses the interchange data and shows stock for salvage yards that subscribe to it's service. IMHO, if it's not listed on car-part.com, good luck finding something. Unfortunately, car-part.com only lists a few places that list the "Axle Beam Rear (FWD)". And, it doesn't seem to list/know-about any matching years/models. That doesn't mean that they don't exist. But, for some reason, GM chose not to list the other models/years as direct replacements. IMHO, shipping would be expensive. Just about every place that lists on that site will also ship. But, for a rear axle, that heavy, big, requires a decent packing job, etc. If I had to make a wild guess, I'd say $100 to $400++ just for S&H. I know the pain you're going through. I spent over a year looking for a "half-decent" rear axle assembly for my '92 Olds Achieva. Most had the spring perch fully or mostly rusted away. After I found one, I cleaned it, sandblasted it, treated it with Eastwood's 3 part rust sealer/preventative, then finally Eastwood's durable chassis paint. My car may only last a few more years. But, at least I won't have to worry about the real axle falling apart while I'm driving again! If you do get it from a place listed, call up, and make very sure it's exactly the part you want. It may not be a bad idea to fax a picture of the part you want to them to be 100% sure. You can send a fax at Staples, and other places. BTW, here are the listings I got from car-part.com : [TABLE=width: 100%] [TR] [TD][/TD] [/TR] [/TABLE] [TABLE=width: 100%] [TR] [TD]Year Part Model[/TD] [TD]Description[/TD] [TD]Part Grade[/TD] [TD]Stock#[/TD] [TD]US Price[/TD] [TD]Dealer Info[/TD] [/TR] [TR] [TD]1998 Beam Axle Chevy Lumina Car[/TD] [TD]STOCK NO. 056523026[/TD] [TD=align: center][/TD] [TD]056523026[/TD] [TD=align: center]$150[/TD] [TD]Ritenour & Sons Auto Wrecking USA-PA(Ellsworth) 1-724-239-2601 [/TD] [/TR] [TR] [TD]1998 Beam Axle Chevy Lumina Car[/TD] [TD]LS,BLUE[/TD] [TD=align: center]A[/TD] [TD]080523[/TD] [TD=align: center]$150[/TD] [TD]A Plus Auto Salvage USA-NC(Maiden) 1-828-466-2211[/TD] [/TR] [TR] [TD]1998 Beam Axle Chevy Lumina Car[/TD] [TD]BASE,BURG[/TD] [TD=align: center]A[/TD] [TD]090233[/TD] [TD=align: center]$150[/TD] [TD]A Plus Auto Salvage USA-NC(Maiden) 1-828-466-2211[/TD] [/TR] [TR] [TD]1998 Beam Axle Chevy Lumina Car[/TD] [TD]RED[/TD] [TD=align: center]C[/TD] [TD]10300[/TD] [TD=align: center]$150[/TD] [TD]A Plus Auto Salvage USA-NC(Maiden) 1-828-466-2211[/TD] [/TR] [TR] [TD]1998 Beam Axle Chevy Lumina Car[/TD] [TD][/TD] [TD=align: center][/TD] [TD]BB1[/TD] [TD=align: center]$Call[/TD] [TD]Mossy Head Auto Parts USA-FL(Crestview) 1-850-892-5333[/TD] [/TR] [TR] [TD]1998 Beam Axle Chevy Lumina Car[/TD] [TD][/TD] [TD=align: center]A[/TD] [TD]C06954[/TD] [TD=align: center]$Call[/TD] [TD]AAA Auto Salvage USA-TN(Lyles) 1-931-670-2223[/TD] [/TR] [TR] [TD]1998 Beam Axle Chevy Lumina Car[/TD] [TD][/TD] [TD=align: center][/TD] [TD]C90003[/TD] [TD=align: center]$Call[/TD] [TD]ABC Auto Parts USA-AL(Birmingham) 205-841-8661[/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] Mechanical Part Grading A = Less than or equal to 60k miles, or greater than 60k miles but less than or equal to 200k miles and less than or equal to 15k miles per year B = Greater than 60k miles and less than or equal to 200k miles but greater than 15k miles per year C = Greater than 200k miles Good Luck! Edited June 28, 2012 by Cutlass350 Quote
Cutlass350 Posted June 28, 2012 Report Posted June 28, 2012 (edited) I may need corrected but I believe any 95-2001 Lumina should have the same support, as well as any 95-99 Monte Carlo Checking car-part.com with those years, gave ~20 results. That seems a little more optimistic that the OP may be able to find one within driving range. What I used for the selection: Axle Beam Rear X Non-Interchange search using Chevy Lumina Car and similar models Non-Interchange search using only Chevy Lumina Car Select year range: 2001 -> 1995 Edited June 28, 2012 by Cutlass350 Quote
wickedbuick Posted June 28, 2012 Report Posted June 28, 2012 Just incase I am not looking at the same part here is a pic. It is the support/cradle/crossmember that you need right? If so, like I said, any 95-99 Monte or 95-01 Lumina should be good vehicles too look for replacement from Quote
