My convert. top won't go down, if I push the switch , nothing happens in the down direction, it will respond in the up direction. Is there a up and down fuse? any other ideas?? Thank you for any help.....
year?
This is likely a relay issue. your relay should be below the motor area... IIRC some cars have two, some have a larger does it all in one relay. it is probably a dirty contact within the relay. Alternatively, it could be a switch issue, but not as likely.
Went out to start trouble shooting the top relays/switch this morning and everthing worked, top went down. Hard to fix if it ain't broke. Thanks for pointing me toward the relay, if ite happens again I at least know where to start.
