GM-4-LIFE Posted June 23, 2012 Report Posted June 23, 2012 Car has a 3.1 in it. Was running perfect and was driveing down the road when it just died. It has spark and fuel pressure. What could.be wrong? Quote
oldscsc Posted June 23, 2012 Report Posted June 23, 2012 Did you put a fuel pressure gauge on it? Just having fuel at the rail isn't good enough, it needs to be within spec (not sure what the spec is off the top of my head). Quote
white96supreme Posted June 23, 2012 Report Posted June 23, 2012 IIRC, it should be at or over 45psi at the rail Quote
ricklovin93 Posted July 2, 2012 Report Posted July 2, 2012 Turn the ignition on take the gas cap off shove your ear in the filler neck and see if you can hear the pump turn on Quote
