Oilpatch197 Posted June 21, 2012 Report Posted June 21, 2012 Anyone know a source?I'm not talking about salvage yards, or Ebay but an established business, that specializes in this stuff. Quote
19Cutlass94 Posted June 21, 2012 Report Posted June 21, 2012 What kinda parts are you looking for? Quote
Oilpatch197 Posted June 21, 2012 Author Report Posted June 21, 2012 Engine compartment fuel line assembly. and the fuel line assembly that goes from the fuel filter to the sender ontop of gas tank.. Quote
urbex Posted June 21, 2012 Report Posted June 21, 2012 Have you checked http://www.gmpartsdirect.com? Quote
1988PhantomFE3 Posted June 21, 2012 Report Posted June 21, 2012 http://www.newgmparts.com/parts/1992/BUICK/REGAL/GRAN%20SPORT/?siteid=213815&vehicleid=1021194§ion=FUEL%20SYSTEM&group=FUEL%20SYSTEM&subgroup=FUEL%20SYSTEM%20COMPONENTS good luck Quote
Garrett Powered Posted June 22, 2012 Report Posted June 22, 2012 rockauto is a good source. not sure what you are after Quote
Crazy K Posted June 22, 2012 Report Posted June 22, 2012 Anyone know a source?I'm not talking about salvage yards, or Ebay but an established business, that specializes in this stuff. Some parts are well supported by quality aftermarket companies. not to mention that "AC Delco" and OEM parts are often out sourced even when new. So, don't worry about it being OEM, worry about it being quality. As for the fuel lines to the tank, the part may be called a Sending Unit. check out all the awesome stuff for sale on Rockauto.com. and if they don't have it, you might have to check with a dealer..... Quote
skitchin Posted June 22, 2012 Report Posted June 22, 2012 Your local GM Parts dealer! These places are suffering pretty bad nowadays to the online wholesalers. Their profits are stretched just about as thin as they go Quote
Oilpatch197 Posted June 23, 2012 Author Report Posted June 23, 2012 Your local GM Parts dealer! These places are suffering pretty bad nowadays to the online wholesalers. Their profits are stretched just about as thin as they go Like I said in the OP, they only had the trunk torsion bars. I think it has to do with GM going under in 2008. It appears I can still get the fuel lines for the tank, but I can't find a source for the engine compartment nylon fuel lines. Other than a custom assembly. Quote
rich17 Posted June 26, 2012 Report Posted June 26, 2012 You'll probally have to make them. Nylon is pretty easy to work with and any Napa should have the stuff on the shelf Quote
Oilpatch197 Posted June 26, 2012 Author Report Posted June 26, 2012 You'll probally have to make them. Nylon is pretty easy to work with and any Napa should have the stuff on the shelf Yes I know NAPA has that bulk nylon and various fittings(even a kit if you want to spend the $$$) But it would look LIKE ASS. Unless there was a way to bend Nylon permanently so it at least travels like the OEM lines. Quote
