92EuroScott Posted June 5, 2012 Report Posted June 5, 2012 I was having a boost problem(which would explain no KR) and narrowed it down to the boost solenoid. Problem is I can't find anyone that sells one, except here. I'm am just not sure it is the correct on for my car. http://www.amazon.com/Turbo-Boost-Control-Solenoid-1997152/dp/B004ZUWNE2/ref=sr_1_1?ie=UTF8&qid=1338896676&sr=8-1 Quote
White93z34 Posted June 5, 2012 Report Posted June 5, 2012 I went through like 3 of those before I found a good one. quick, dirty solution is to just disconnect the lower vacuum line from the BCV and let the cars own vacuum run it, the one you posted at least looks right, I'd be able to say better if i had one in front of me. Quote
base93lumina Posted June 5, 2012 Report Posted June 5, 2012 Wont doing that throw a light? I thought it had to stay hooked up to not wind up in limp mode? I hate having an electric solenoid inline with my bypass valve. Quote
Penglii Posted June 5, 2012 Report Posted June 5, 2012 The one you listed is the one you need, that is also a good price... they also have them on RockAuto, but they cost $50+shipping. Also... GM used the same boost solenoid on the supercharged 3800's. Quote
95 vert Posted June 5, 2012 Report Posted June 5, 2012 Wont doing that throw a light? I thought it had to stay hooked up to not wind up in limp mode? I hate having an electric solenoid inline with my bypass valve. Will not set any codes if you unhook the vacuum line only as White93z34 said. Quote
92EuroScott Posted June 5, 2012 Author Report Posted June 5, 2012 I have a supercharged 3800. I just wanted to make sure I found the right part. I heard I could bypass it but would rather just fix it. Also, I couldn't find anything on rockauto or any parts store sites. I went to Oreilly's today and he had to call the dealership. He was able to find me one for $45 and gave me a part number in case I wanted to look around. The part number he gave me was 1997244. Quote
Penglii Posted June 5, 2012 Report Posted June 5, 2012 Yes, that part number looks to be the same part. I'd personally go with the Amazon one you found, since it's cheaper... but that's just me. Quote
carkhz316 Posted June 6, 2012 Report Posted June 6, 2012 Just do what White93z34 said and unhook it. It's not really need anyway. It's only for reverse and wheel spin to limit boost, and your engine will operate just fine without it. I did this to my top-swapped Monte as it was junk and I didn't want to buy a new one, and didn't see the need for it. Quote
92EuroScott Posted June 6, 2012 Author Report Posted June 6, 2012 (edited) If I bought one it would be the amazon one. So unhooking it from just the vacuum house I already took off? Not the connector that runs to the PCM? Edit: I usually drive with traction off, so the wheel spin thing wont cause an issue. Edited June 6, 2012 by 92EuroScott Quote
95 vert Posted June 6, 2012 Report Posted June 6, 2012 Leave the electrical connector plugged in. Just the vacuum line unplugged. Quote
92EuroScott Posted June 6, 2012 Author Report Posted June 6, 2012 As I thought. Thanks for the help guys. Quote
