digitaloutsider Posted June 4, 2012 Report Posted June 4, 2012 They're both Gen 3 M90s and they both bolt up the same. I'm running a 2002 blower on my 97 GTP, using the 2002 vacuum routing. Quote
base93lumina Posted June 4, 2012 Author Report Posted June 4, 2012 So really, its just a vacuum routing thing. Sweet, i'll just cap that hole and call it a day. Since my car is a 2000, with that port closed off its not gonna hurt anything. I noticed the only vac lines on my car is the ones on top of the S/C Inlet behind the TB; unless im blind. Quote
base93lumina Posted June 4, 2012 Author Report Posted June 4, 2012 And just for the record.....OMFG does that oil in these things stink! WOW!!! And i though diff oil with LSD additive was bad! Quote
GtpKo Posted June 5, 2012 Report Posted June 5, 2012 Yes, it's the kind of ass-smell that gets stuck in your nose all day. It's the superchargers natural defense mechanism against predators. Quote
base93lumina Posted June 5, 2012 Author Report Posted June 5, 2012 Are the lower intake manifolds the same between the 96-97 and 98-03? Or are they all the same? Quote
GtpKo Posted June 5, 2012 Report Posted June 5, 2012 I believe they're mostly the same from 96-05 as long as they used a gen 3 M90. Quote
base93lumina Posted June 7, 2012 Author Report Posted June 7, 2012 Cool, cause i still have one more case to pick up and i get both the upper and lower manifold as 1 unit for $25. And since its a gutted blower, they consider it an intake manifold Quote
digitaloutsider Posted June 7, 2012 Report Posted June 7, 2012 Like I mentioned above, I have a '02 blower on my '97. Same LIM. Quote
base93lumina Posted June 9, 2012 Author Report Posted June 9, 2012 Wasnt sure if the early manifolds were different in castings. Kinda like the early 3400s and late 3400s were where they had crappy castings. But i guess not Cool, back to the yard to get the other lower manifold Quote
base93lumina Posted June 15, 2012 Author Report Posted June 15, 2012 So i got the other casing and lower manifold, and this time i managed to sneak an extra throttle body out in the whole package. The guy looked at it and said "what the hell is that?" and i told him it was all one unit just broken down. He said okay and charged me for another intake manifold I love it when you catch them on a day where they could give a shit lol On another note, i managed to get the case bearings out of the 98 housing i have. A couple of 8x1.00mm zert fittings and a grease gun worked perfectly! I was actually amazed how well they came out. The only crappy part was where i when the first bearing popped out and a small shot a grease that followed it landed in my eye. But, other than that, it went as planned. Now, im unsure, does anyone know if the bearings for the bypass butterfly are available anywhere? Quote
