headlight problem...
91 GTP.. if i try and turn on the headlights with the fogs.. i'll be driving and then all of a sudden.. no more lights.. they all go out. dangerous on the road. then about 5 seconds later, they come back on ?? anyone know what's going on? same thing if i turn the highbeems on; fogs go off.. like they are supposed to but like 2 minutyes later.. no more lights. this ever happen to anyone else? any ideas?
thanks,
-canusa
Check your headlights/foglights relay. They could be failing. If you have another device that uses the same type of relay like your headlights/foglights relay then try to swap them temporarily and see if that makes a difference. If the headlights/foglights works fine when using another relay then it's time to buy a new relay.
