19Cutlass94 Posted May 25, 2012 Report Posted May 25, 2012 So while doing my swap, I put the interior somewhat back, however there is this one connector that I cannot find a home for. Its on the drivers side, right by the e-brake. its a two wire, and its a yellow/orange. Even though it looks grey/brown. In this picture is about as far as it will go. Quote
ManicMechanic Posted May 25, 2012 Report Posted May 25, 2012 Yellow/orange or possibly white/orange? If it's white/orange, those usually go to the interior light circuit. Quote
19Cutlass94 Posted May 26, 2012 Author Report Posted May 26, 2012 Ill have to double check and make sure, but I coulda sworn I didnt even touch the light there. Quote
Bake82 Posted May 26, 2012 Report Posted May 26, 2012 I 've hooked that connecter up a 100 times..but damn I can't remember exactly what it is....Check the e-brake light switch, I think it's attaches to the pedal somewhere to throw the dash light for ebrake. Quote
19Cutlass94 Posted May 30, 2012 Author Report Posted May 30, 2012 Well I forgot to check the light there, but I didnt see any connector around the e-brake at all. Except for a single prong connector which was already connected... Quote
rockfangd Posted June 13, 2012 Report Posted June 13, 2012 the park brakee indictor is a single prong. usually orange wire. That looks like the connector for the underdash interior light, right near the park brae pedal Quote
19Cutlass94 Posted June 13, 2012 Author Report Posted June 13, 2012 Ive started the car up, checked all the lights, interior lights, everything works. and that plug is still unplugged. So im clueless as to what it could be.. Quote
jrcuttymann Posted June 13, 2012 Report Posted June 13, 2012 It might be the wiring connector that attaches to the trunk release button, unless you already have that feature, if not you would also need the trunk release module that goes on the trunk lid, if you look there you will find another connector either loose or taped up in the harness somewhere. Quote
rockfangd Posted June 14, 2012 Report Posted June 14, 2012 oh that would be cool if it were prewired for electronic trunk release. My 94 didnt have it till I installed it But I put the button in the glove compartment. I thought the plug for the button was different though. But anyway it would go on the panel below the steering column forwrd of your left leg. good thinking Quote
rockfangd Posted June 14, 2012 Report Posted June 14, 2012 ok I have looked into it and hee is what I have. interior lamps are orange and white trunk release switch is lt green/ blk and black/ white. Are you sure of the wire clors you have mentioned because if you are I am lost at the moment Quote
