91-93 LQ1 into a 95 Convertible?
Hello, can I install a crated LQ1 intended for 91-93 model years into my 95 convertible? What are the issues? Thanks in advance!
You'll need to reuse your front cam carrier, and install the newer style harmonic balancer and crank pulley.
I know the front cam carrier will need to be swapped over. Front timing cover will need to be swapped around too for the secondary crank sensors.
