Help, advice.
The 92 cutlass that I put money down, he just mentioned this about the trans. The engine doesn't run so I can't drive it to check. The guy says this about the transmission, "if you are driving it hard it sometimes growls a bit into 4th gear. If you shift slowly it never makes a sound" He said it has done this for 40k miles. Is this normal for 284's?
Sounds like gearing is going? Who knows more about these trans?
Its the synchronizers going out, but like he said, go easy into 4th and it'll be fine
Yeah just a synchroniser going out, my old 284 did it for a long time and never got any worse, shame as you'll have to find a good used one as rebuild parts are simply not available to any one at any price.
Then if it is synchro , if if gets worse it simply won't hold in gear, if I remember basics.
So, now I wonder if it's worth the $900 it's going to cost to buy/deliver to my house. It is the 92 intrn'l that I posted earlier? I was going to put my DOHC motor in it and sell it. Or convert to auto and sell. I have 3800 conversion that is causing me to have extra trans/engine. Mmmm
I drove mine grinding on 3rd gear shifts for a long time, I found double clutching helped some. Never came out of gear though. I spent a few months a few years ago calling every trans rebuild outfit in North America, and Getrag gears North America (who told me to piss off in more words) and no one carries / makes these parts :mad:
It kept on going till the engine in the car blew up and I stripped it for parts. I used a different trans on my current z34, that thankfully is fine.
Yeah I had 2 at the time so when I was building my current z34 I used the other one.
Now I have to decide wether to keep car, or part it out. Again I could just back out of the deal. Anyone live closer to Michigan and can use the car?
