3.1 Radiator Replacement Size Compatibility 5/8, 1, vs. 1.25 ???
Hi all!
I'm look for guidance if i can simply replace my current radiator with the largest size as all the sites say each size will work for my '97 olds cutlas.
I've read on some post that going larger would require a different driver side fan, but each that i read wasn't a 3.1...
Does anyone know if this is the case?
If so, do you order the fan based on the radiator size?
Thank you!
You can use a 1 /38" thick radiator from:
CUTLASS 94-95 6-207 (3.4L)
GRAND PRIX 94-95 6-207 (3.4L)
LUMINA CAR 94-95 1-3/8" thick
MONTE CARLO 95 1-3/8" thick
Without any mods.
