Anyone know what the best way to remove a front door window regulator is? Do you have to drill it out or can you hit the stem coming out of the rivet with a hammer and punch it through? Need to get the window down on my parts car. It's 20 miles away so I want to make sure I have the right tools with me, and getting power for a drill may be a challenge.
If you do not have an electric drill a good 12 volt battery drill with a decent charge will do the trick, I have done a couple, or you can grind the heads of the rivets and punch them through.
