qwick6 Posted April 16, 2012 Report Posted April 16, 2012 I searched and can not find a vacuum diagram for a 95 LQ1. The question that I have is the line goes from the ball to the check valve then one line goes to the HVAC but where does the second line go. I looked at my 93 and the second line goes to the back of the map but where does it go on the 95. Quote
Schurkey Posted April 16, 2012 Report Posted April 16, 2012 I searched and can not find a vacuum diagram for a 95 LQ1. The question that I have is the line goes from the ball to the check valve then one line goes to the HVAC but where does the second line go. I looked at my 93 and the second line goes to the back of the map but where does it go on the 95. Going from memory...but doesn't the '93 tee off to the cruise control servo? I was sure the vacuum comes around the back of the engine, and "Y"s to the cruise control on one branch and to the reservoir ball on the other. Quote
z34Phoenix Posted April 17, 2012 Report Posted April 17, 2012 on my 96 there was a tree that fed the brake booster and then the vac ball. from the pics i have i would say look around the EGR and on the MAP on the pass side of the UIM. Quote
qwick6 Posted April 17, 2012 Author Report Posted April 17, 2012 on my 96 there was a tree that fed the brake booster and then the vac ball. from the pics i have i would say look around the EGR and on the MAP on the pass side of the UIM. I do believe that it connects on the intake near the EGR. Are you saying that perhaps it connects to the brake booster as well. Is it possible to post the pics you have. Quote
