3pt1lumina Posted April 15, 2012 Report Posted April 15, 2012 My dad's 1998 Monte Z34 with the 3800, I need to replace the valve cover gaskets on it. It looks like a straightforward job, just wondering if there is any tips or tricks you guys have for doing these, especially the rear one. Going to try it out tomorrow night after work. Thanks! Quote
carkhz316 Posted April 16, 2012 Report Posted April 16, 2012 The rear one is almost easier than the front, as you only need to undo the alternator and it's rear support bracket in order to get the valve cover off. Quote
9lumina6 Posted April 16, 2012 Report Posted April 16, 2012 (edited) Make sure you guys got the upper and lower Coolant elbows too. Considering the old ones will most likely will crack apart when taking the Alt. bracket off. Wish I could stop by and give ya a hand with it, but I'll already be out on the road for the week. Edited April 16, 2012 by 9lumina6 Quote
3pt1lumina Posted April 16, 2012 Author Report Posted April 16, 2012 Yup I do have the elbows just in case. Quote
carkhz316 Posted April 16, 2012 Report Posted April 16, 2012 You won't need the coolant elbows. If you remove the alty/ tensioner bracket, you are doing extra, unnecessary work. 98-99 Monte's with the L36 will have the alty/ tensioner setup that you'll find in all the 98-earlier L36's. Old style have bolts horizontally, plus a rear support bar. 99+ (on all BUT the 1.5 gen Monte's/ Lumina's) will have the vertical bolts for the alty. IIRC, there is only one serviceable coolant elbow on the <98 setup, and that's the infamous LIM one. Quote
rich17 Posted April 17, 2012 Report Posted April 17, 2012 I learned a trick. Take some clear synthetic lubricant like for brakes or something and use it on the head. Also if the elbows havent been done I'd do them before they go. And its also good to use a lubricant on them as well to make them easier to go in. I use a product from Napa called Syl-glyde. Great stuff. I use it on everything. Quote
3pt1lumina Posted April 17, 2012 Author Report Posted April 17, 2012 Update to anyone trying it (who hasn't done it) it wasn't too bad. Like what was stated above for the rear, took two bolts off of the alternator, swung it forward and removed the bracket that ran along the intake as well. For the front had to unbolt the one dog bone mount from the ICM bracket, and unbolt the ICM bracket from the engine in order to lift the front one up. I ran out of time last night to finish but both are installed front is completely back together. I just need to put the alternator/bracket back just make sure everything I unplugged is back together. Quote
