ricklovin93 Posted April 13, 2012 Report Posted April 13, 2012 4T60E, This "clunk" happens when: 1. shift from reverse to drive 2. get on the gas after coasting 3. downshift a gear Im guessing that the cv axle needs to be replaced since this started when i blew a ball joint and the axle flew out of the transmission, any other causes? Quote
94 olds vert Posted April 13, 2012 Report Posted April 13, 2012 Transmission mount. Fairly easy to replace. That would be my guess. Quote
ricklovin93 Posted April 13, 2012 Author Report Posted April 13, 2012 looks pretty accesible i should of replace it while i was replacing the rotors and pads Quote
RobertISaar Posted April 13, 2012 Report Posted April 13, 2012 honestly, it sounds like it could be either. take a look at the trans mount at least. or have the hood open and watch for powertrain movement when shifting. Quote
ricklovin93 Posted April 13, 2012 Author Report Posted April 13, 2012 when in reverse foot on brake and giving some gas the engine goes down and towards the back, alottttttttttttt Quote
ricklovin93 Posted April 13, 2012 Author Report Posted April 13, 2012 okay now i know the one at the front of the engine (by the harmonic balancer) is completely shot, i can pull chunks of rubber off of it, how many more mounts are there? just one more on the drivers side right? Quote
RobertISaar Posted April 13, 2012 Report Posted April 13, 2012 i can think of 4. the two dogbones on the core support, the lower mount for the engine and the trans. Quote
ricklovin93 Posted April 13, 2012 Author Report Posted April 13, 2012 well besides the dogbones, they look in pretty good shape Quote
ricklovin93 Posted April 13, 2012 Author Report Posted April 13, 2012 BTW rob love the website, too bad i dont have obd1 because you got some good info on there Quote
RobertISaar Posted April 13, 2012 Report Posted April 13, 2012 BTW rob love the website, too bad i dont have obd1 because you got some good info on there i go entire months without thinking about it.... it sucks and needs revamped. Quote
ricklovin93 Posted April 13, 2012 Author Report Posted April 13, 2012 Just start your own tuning business man, you seem to know a lot of shit Quote
RobertISaar Posted April 13, 2012 Report Posted April 13, 2012 nobody locally has any money, so i'd be in the same situation i'm in now: mailing and emailing tunes. anyways, back on topic, there is a FAQ for changing the lower motor mount and it's quite useful. i don't think there is one for the trans, but you never know. Quote
ricklovin93 Posted April 13, 2012 Author Report Posted April 13, 2012 after reading the write up it seems pretty straight forward, do you think the transmission mount removal/install is similar? Quote
RobertISaar Posted April 13, 2012 Report Posted April 13, 2012 seems easy enough. http://i.imgur.com/181he.png http://i.imgur.com/m3QNh.png http://i.imgur.com/viLSi.png you'll probably need the second set of those. Quote
