Disbass69 Posted April 12, 2012 Report Posted April 12, 2012 So I have a 1994 cutlass vert and it has the digital climate control Last winter I had a vacuum leak and the front vents stopped working, I got that fixed and it all works now About 3 months ago however my climate control started acting weird, It stays on and the screen freezes leaving the heat on where ever you left it. This was fine in the winter but now that it's warm it gets a little to warm. It will work for the first 20 mins after the car has been off for a couple hours but then it freezes and you have to leave the car off for a couple hours. Do I need a whole new unit or is it something else? Problem #2 It has a whine. Can't figure it out, I thought it was the power steering but it gets louder when you get on the gas, Its been like this for a year since i bought it and i can't figure it out. Anybody have any ideas on what it could be? Quote
RobertISaar Posted April 12, 2012 Report Posted April 12, 2012 describe the whine. quick test to see what it could be would be to remove the serpentine belt then spin as many pullies as you can by hand. if one of them is making significant noise, it may be your problem. or you could be really unlucky and have it be the transmission. Quote
94 olds vert Posted April 12, 2012 Report Posted April 12, 2012 Do you have a video of the whine? Quote
Disbass69 Posted April 12, 2012 Author Report Posted April 12, 2012 http://www.youtube.com/watch?v=EFM99Nd-FKs&feature=youtu.be Just took one Quote
94 olds vert Posted April 12, 2012 Report Posted April 12, 2012 I'll say a power steering pump is causing that. Mine used to sound very similar to that. Turn the wheels to lock and does the sound get louder/higher pitched when you rev it? Check your fluid if it's not full fill it up. I ended up draining all my power steering fluid and replaced with Bar's power steering fluid. Worked pretty good. Quote
Disbass69 Posted April 14, 2012 Author Report Posted April 14, 2012 Yes it does ima try the draining and replacing once i actually get a day off anyone got any ideas on the climate control? can deal with the whine but the 90degree heat that's on in 80 degree weather is starting to become real hell lol Quote
94 olds vert Posted April 14, 2012 Report Posted April 14, 2012 Those ECC units are known for going out and having strange problems. To replace it you will need another 1994 unit. Quote
willsboattail Posted April 20, 2012 Report Posted April 20, 2012 My 93 3.4 vert whines the same... I keeping adding stop leak power steering fluid as I have a line leak. It goes away with each add. Hopefully the stop leak will stop the leak. (Hopefully) I've noticed similar whines with many GMs of that era I pass on the streets! :think:Climate Control, I dunno:think: Quote
DawnetteStump Posted October 6, 2013 Report Posted October 6, 2013 I see the last activity on this subject was in 2012 but I have a suggestion on the climate control issue. Last fall my 93 would only allow hot air through the vents. After replacing a blend door (which I now believe was perfectly ok) if didn't fix the problem. After researching it, I decided to replace the automatic temperature control sensor located under the clove box. It was plug and play. I found one on the internet. I replaced it and fixed my problem. Maybe it could be the sensor not working? Quote
jmblimo Posted October 16, 2013 Report Posted October 16, 2013 I had a bad whine with my '94. I thought it was a timing belt pulley but was the AC compressor. Quote
