croslace difference
ricklovin93
whats the diference between the pontiac crosslace and the oldsmobile crosslace, are they the same size and offset? Which one can i fit wider tires on?
Edited by ricklovin93
Link to comment
Share on other sites
Olds wheels are 6.5" wide and I think they are 15" wheels and look like this:
1st gen Pontiac Grand Prix ones are 8" wide and 16" tall and look like this:
Bonneville xlace ones look the same as the GP ones but are only 7" wide:
Second Gen xlaces are known as torque laces and look like this:
Link to comment
i can run the 1st gen gp xlaces in my cutlass with no problems right? they are not to wide are they? Im worried about the offset, and and if the tires will rub in the wheel wells.
Link to comment
DROOL! I was wondering what the 90 back blackened tail lights would look like on my 95 black sedan.. That is one sharp looking car! Droooll.....
Link to comment
Thanks
Rims are the 16x8" cross laces
Tires are Hankook Ventus RS2 245/45/16 in the front and Hankook Ventus RS3 225/50/16 in the rear
The RS3's are a touch narrower, but they are quite a bit more sticky so its a pretty even balance
Link to comment
Depends on the car. Also depends on the tire size. I rock nothin less then 245/50/16 on laces. Period.
Oh btw. Found out doing the 96+ front knuckle swap, pushes out the front wheels a bit. Noticed the difference between my White Lumina and Silver Lumina.
Link to comment
just ask austin (white4d96) he has my old crosslaces on his car
they stuck out like an extra inch or so. im pretty sure he has pictures in his project thread
EDIT: found it, the first post with them is #220, then theres a few more in pages after that http://www.w-body.com/showthread.php/47838-White4d96-s-3100-SE/page15
Edited by iroc2
Link to comment
Curious: How many different "finishes" were available on the Pontiac Crosslace wheels?
I just bought a set from a '93 GP; I thought they were going to be gold, but if they were...the gold came off with the brake dust when I cleaned 'em.
Used plain old Simple Green and a toothbrush. (These wheels were FILTHY, one was so bad that at first I thought it had been through a fire--but there's no sign of melting or heat distortion, and the tire is fine. Just really, really covered in ick.)
At any rate, they've got corrosion issues around the edges and they're plain aluminum-colored in most places now. I'll probably have to have the tires removed to address some bead-leak issues.
Came with two decent and two usable-for-a-little-while tires, and the price was very acceptable.
Link to comment
