Installing a rear swaybar
Hey, right now i do not have any rear sway bar on my 1993 Cutty. I would like to add one, probobly the biggest stock one made, not the addco one. Does anyone have any detailed pics of theirs or have directions on how i could add one.
I just put a rear sway bar on the back of my Lumina and it wasn't too hard but here is something to look out for. Since my Lumina didn't come with a swaybar, there were no nuts in the holes for the brackets. I ended up welding the brackets on.
Also, to get the bar on, you'll have to drop down a strut. When I did this, I sheared off a bolt head and spent the next three hours drilling the bolt out. So, be careful with the strut bolts, use lots of your favorite penetrating oil and use a 3/8" drive ratchet, a 1/2" was what I used and sheared the head right off.
Side note, the largest factory rear swaybar, if I recall correctly, is 12mm.
i was looking at the rear sway bar on a 96 lumina. its 7/8 of an inch and it looks like it will fit on the older luminas. anyone done this?
GEt a metal shop to make one it should cost between 80 to 100 Cnd for me to make one for my lumina
I bought mine from a JY and spent only $12.85 for it and all the hangers.
