95regal Posted April 4, 2012 Report Posted April 4, 2012 i parked my 95 regal at wor and when i went to back out i hear a pop! so i go and look and see my d/s balljoint poped out of the cup.is there any way to fix this on ther spot?the joint is rivited in which is no problem but how do i get the ball end out of the control arm? thanks!!!!!!!!!!!! Quote
jman093 Posted April 4, 2012 Report Posted April 4, 2012 Remove the cotter pin and go to town on the ball and stud end with a hammer. It'll come out of there. The replacement ball joints will have screws instead of rivets. Quote
95regal Posted April 5, 2012 Author Report Posted April 5, 2012 i find it's hard to hit the stud because there is not much room under the car.should the rivits be drilled from the top or bottom? btw jesse i also have a g-body (86 442)and a b-body (95 roadmaster estate) thanks for the help! Quote
White93z34 Posted April 5, 2012 Report Posted April 5, 2012 I think harbor freight sells a balljoint press of sorts that might be able to pop it out Quote
alec_b Posted April 5, 2012 Report Posted April 5, 2012 He needs a ball joint separator, which harbor freight also sells. Be aware though, most of the W's I've done have been REALLY stuck in the control arm. I actually broke my first ball joint separator on one. A pickle fork may be better. Quote
tornado_735 Posted April 5, 2012 Report Posted April 5, 2012 You're going to need a pickle fork. I've changed a few ball joints on W's, and Alec isn't exaggerating. Quote
White92Cutlass Posted April 5, 2012 Report Posted April 5, 2012 Autozone loans ball joint separators Quote
95regal Posted April 7, 2012 Author Report Posted April 7, 2012 IT's DONE! i just finished the balljoint replacement,and just like you guy's said it was rough.i had to rent a balljoint press use a pickle fork, chisels and a few other tools.i did both sides and it rides like a new car, i thought the banging over bumps was the motor mounts and never thought it was the ball joint. THANKS for all the help!!!!! Quote
Schurkey Posted April 7, 2012 Report Posted April 7, 2012 Now you know the value of inspecting the steering/suspension/brakes/tires periodically. Quote
Red Nightmare Posted April 8, 2012 Report Posted April 8, 2012 Good thing it didn't decide to break on the highway. Quote
iroc2 Posted April 18, 2012 Report Posted April 18, 2012 mine broke at ~20-25 around a corner had a "well theres that noise i couldnt find" kind of moment... Quote
