ricklovin93 Posted April 4, 2012 Report Posted April 4, 2012 Exactly what should the lug nuts be torqued too? Quote
AMP Posted April 4, 2012 Report Posted April 4, 2012 I never torque mine I just tighten them as tight as I can get it which IMO is good. Quote
RobertISaar Posted April 4, 2012 Report Posted April 4, 2012 I never torque mine I just tighten them as tight as I can get it which IMO is good. unbalanced lug torque can cause rotor warpage among other fun stuff. 100ft/lbs that's what i use. works well for me. Quote
AL Posted April 4, 2012 Report Posted April 4, 2012 100 ft/lbs is whats recommended from the factory... Do NOT do what AMP does Quote
urbex Posted April 4, 2012 Report Posted April 4, 2012 Over torquing does not mean that it's on tighter and better. Just because it's tighter doesn't mean it will hold. There are reasons why engineers figure out the proper rating. Quote
White93z34 Posted April 4, 2012 Report Posted April 4, 2012 I started doing 100 ft/lbs after I got sick of breaking lug studs by not properly torquing them. Quote
GOT2B GM Posted April 4, 2012 Report Posted April 4, 2012 Ask Jamie how much fun it is when you over-torque your lug nuts and all 5 studs simultaneously shear off your RF wheel at 120 km/h on the 401 Quote
ChibiBlackSheep Posted April 4, 2012 Report Posted April 4, 2012 Whenever I get my car back from a shop (after inspection, or anything else) I always pop the car in the air and retorque the wheels. They just use impact guns and never properly torque. I have also seen how a properly torqued wheel can extend the length of your brakes, and also we have so many hub problems already with W-Bodies, overtightening the wheels can add to those too I'm sure. Quote
3pt1lumina Posted April 4, 2012 Report Posted April 4, 2012 I do mine at 100ft/lb as well. Never had an issue and if anyone else ever touches my wheels I always re-torque them myself. Quote
meltboy1 Posted April 4, 2012 Report Posted April 4, 2012 Guess who is retorquing their wheels when he gets home tonight...lol I never thought of the consequences. Quote
skitchin Posted April 4, 2012 Report Posted April 4, 2012 How the hell do torque wrenches like this work?: http://www.harborfreight.com/1-2-half-inch-drive-click-stop-torque-wrench-239.html Are they even worth a shit? Wondering if I should buy a torque stick set, one of the cheapos above, or just cash out for a nice craftsmen electronic torque wrench? Quote
urbex Posted April 4, 2012 Report Posted April 4, 2012 You just tighten until it clicks. Pretty easy to use. That's what I have essentially (although mine isn't harbor freight) Quote
White93z34 Posted April 4, 2012 Report Posted April 4, 2012 Torque sticks are stupid and inaccurate. I have that same (or very similar torque wrench Purchased from Wal-mart) I have beat the crap out of it for years now, It seems to work good, and after all that is nearly spot on with my good craftsman torque wrench. I keep it just for lugnuts these days. Sometimes HF will price it as low as $10. Quote
skitchin Posted April 4, 2012 Report Posted April 4, 2012 Stupid question, but how do you select the torque with the one I linked? Is there just some adjustment on there, or? Quote
ChibiBlackSheep Posted April 4, 2012 Report Posted April 4, 2012 Stupid question, but how do you select the torque with the one I linked? Is there just some adjustment on there, or? On the bottom is a knob, you loosen it, and then you twist the handle until the arrow is on the torque setting that you want, then you tighten the bottom knob to lock it in place. When you are done you loosen and set to the lowest torque value, tighten, and store. Quote
skitchin Posted April 4, 2012 Report Posted April 4, 2012 Thanks Chibi, nothing I could find online explicitly said or showed it was adjustable at all. Just wanted to make sure I was comprehending how these things work Quote
spiderw31 Posted April 4, 2012 Report Posted April 4, 2012 (edited) Stupid question, but how do you select the torque with the one I linked? Is there just some adjustment on there, or? The end of the handle rotates, and there is a lock nut to hold it down. Rotate to set the torque, and then tighten the lock nut to keep it from moving. Edit: Bah! Chibi beat me to it! Edited April 4, 2012 by spiderw31 Quote
ChibiBlackSheep Posted April 4, 2012 Report Posted April 4, 2012 Thanks Chibi, nothing I could find online explicitly said or showed it was adjustable at all. Just wanted to make sure I was comprehending how these things work haha no problem! I believe that one has 10 lb. increments and dashes in between. It's really easy to figure out once you are holding it Quote
AL Posted April 5, 2012 Report Posted April 5, 2012 Make sure you always set it back to 0 so it stays accurate for years Quote
WhatTheFehl Posted April 5, 2012 Report Posted April 5, 2012 Actually, setting the torque wrench back to zero for storage can damage the springs causing it to not be accurate at all, or even break completely. The owners manual for mine says to keep it at the lowest torque setting (10 pounds for mine) to keep this from happening. We also follow the same policy at work, since apparently over the years we have broken many torque wrenches by setting them back to zero. We were actually recommended to leave them at the lowest torque setting by the company that warranty repairs every one of our torque wrenches. Quote
ChibiBlackSheep Posted April 5, 2012 Report Posted April 5, 2012 The owners manual for mine says to keep it at the lowest torque setting (10 pounds for mine) to keep this from happening.. Exactly why I pointed that out in my post Quote
skitchin Posted April 5, 2012 Report Posted April 5, 2012 Thanks again for all the info! Going to buy one, and now I'm educated enough to make it last! Quote
AL Posted April 6, 2012 Report Posted April 6, 2012 Actually, setting the torque wrench back to zero for storage can damage the springs causing it to not be accurate at all, or even break completely. The owners manual for mine says to keep it at the lowest torque setting (10 pounds for mine) to keep this from happening. We also follow the same policy at work, since apparently over the years we have broken many torque wrenches by setting them back to zero. We were actually recommended to leave them at the lowest torque setting by the company that warranty repairs every one of our torque wrenches. This is what I meant, ignore my other post Quote
Schurkey Posted April 6, 2012 Report Posted April 6, 2012 I never torque mine I just tighten them as tight as I can get it which IMO is good. replaced two lug bolts broke clean off Hmmmm. How the hell do torque wrenches like this work?: http://www.harborfreight.com/1-2-half-inch-drive-click-stop-torque-wrench-239.html Are they even worth a shit? Cheap precision tools are often worse than no precision tools. They provide a false sense of security. "I" would give a Harbor Fright torque wrench a "flotation test". Throw it in the lake or river: If it floats back to shore, take it home and use it. If not... Quote
