madmax Posted October 26, 2003 Report Posted October 26, 2003 Where is the tps on a 88GP 2.8 located on the tb and whats the procedure for removing it? Also, is advisable to clean or replace it? I just cleaned out the iac valve which was gunked up and I'm thinking that the tps may need the same. Thanks. Max Quote
Robby1870 Posted October 26, 2003 Report Posted October 26, 2003 The TPS is located on the left side (if you're looking at it) of the Throttle Body. You cant clean it, its a sealed unit. If its bad, you just have to replace it. I think its 2 or 3 screws, Im not for sure. Your best bet is to take the TB off to take it off. A bad TPS will usually cause a stumble when you take off from a stop sign Quote
