Mel87 Posted March 20, 2012 Report Posted March 20, 2012 Yeah uh that light came on out of no where today and won't go off, I guess have it scanned because from what I can visually see and hear nothing seems out of order on the Cutlass.. Quote
Psych0matt Posted March 20, 2012 Report Posted March 20, 2012 Yeah uh that light came on out of no where today and won't go off, I guess have it scanned because from what I can visually see and hear nothing seems out of order on the Cutlass.. Congratulations. Was there a question involved in this post? Just giving you crap Quote
Red Nightmare Posted March 20, 2012 Report Posted March 20, 2012 If it is the 87 - Under the dash there will be a plug you can hook a jumper wire (any piece of wire will do just hit the right connections) and the SES light will flash out the codes and you then cross-reference that to a haynes manual or just dig them up on the web, real easy. If it is the 97 - Just take it to autozone, they can hook up a scanner and get the codes and it costs nothing. My 94 has the SES light come on occasionally but since a special scanner is needed for the 94 I don't even bother. Eventually it will shut off again. Yeah, 94 sucked. it was not OBD 1 or 2 but some inbetween bullshit Quote
RobertISaar Posted March 20, 2012 Report Posted March 20, 2012 93-95 3100, 94-95 3.4 and 94-95 3800 are all readable by a DIY scanner even. i would know, i've built many. i've tuned all 3 before as well. Quote
WhatTheFehl Posted March 20, 2012 Report Posted March 20, 2012 If the code is for the EGR, it most likely has not failed, but instead become clogged. I have a writeup in the FAQ section about it. Quote
Mel87 Posted March 20, 2012 Author Report Posted March 20, 2012 Well I got it scanned and it said cylinder #1 misfired 386 times. I had him clear it and so far it hasn't come back on. Quote
