I like the looks of wider tires I currently have 215 on my 15 steelies what's the widest I can use in these wheels
Get a set of crosslaces and run a 245 45 16 on them... The widest you can run on your steelies is a 225
Just a side note, tires wider than what's recommended for that width rim will roll more easily in the corners. Wider tires will also have a slight impact on fuel economy due to both drag and rolling resistance. I'd run a 215 if I were you.
factory tires on a 15" steelie are 205, i'm running 215 on mine, not sure if i'd try and go wider though. it's a 6" wide wheel (supposedly) and the tread width at 215 is ~8.5"
  • 3 weeks later...
