exhaust / mufflers???
I was wondering what the guys with 3.1's are running for exhaust systems. right now i'm running a glass pack along with the stock dual mufflers. It doesnt sound bad but i wat something a little more agressive sounding, but not too ricey sounding. just trying to get some ideas...thanks
cut off the exhaust either right before or after the cat.
it will sound more agressive than it has any right to.
currently im stock but i have been looking...what i want to do is do a muffler delete and shorter res with cat. try looking up some videos on youtube.
if you want to stay with mufflers then i would suggest borla universal and have them welded on, borlas can make anything sound good.
I would actually go with Magnaflows on these engines just due to every other muffler wanting to make the exhaust sound raspy as hell and just not good in general
Wouldnt you have backpressure issues if you did that? And could you still pass an emissions test if everything was to come off after the cat?
you can still pass emissions as long as the cat is there and functioning.
and backpressure? why does everyone think you NEED backpressure? stuff a potato into your exhaust if you want backpressure.
Not sure on the laws where everyone else is at, but apparently Missouri has some rules regarding state inspections that you must have a catalytic-converter(if you vehicle is past a certain year, 70's or so), and a fully enclosed air cleaner(i.e. stock box). So might not need cat for emissions but around here you can fail a state inspection for not having one.
Back in the day I was considering an electronic cutout valve in place of my cat, but I have yet to hear a V6 that sounded good running open heads.
Im running stock with a pretty decent amount of rust/holes in the mufflers.
and it probably sounds awesome.
there aren't many ways to go wrong on the OHV 660s.
If Missouri is like most states, it only has to be PRESENT, not necessarily functioning....
or if you state is like wis. and you dont have emissions tests just do what i did cat delete and go to j/y find a good muffler take a grinder cut it open gut it and weld back shut so it looks like you still have a muffler if you get pulled over
Where my car is registered(outside of St. Louis County) I don't need emissions, but also because my car is so old(95) it doesn't need to pass them anyhow. Since we're on the topic, how hard is it to tune the cat/o2 sensors out of an OBD 1.5 vehicle? OBD 2 conversion required?
no 3100/3.4 car before 1996 has a secondary O2 sensor (meaning the one behind a cat in OBD2 cars), so you can remove it and it would never know.
if you were trying to remove the only O2 sensor, you would disable closed loop fueling, which is possible to do and the tune can be setup for it, but why?
Keep the cat (if it's in good shape and not plugged), add a long resonator, and delete the mufflers, just run piping to the tips.
I know for a fact my cat has a minimum of 100,000 miles on it, might be about that time.
2.5 Stainless Piping
Magnaflow High Flow Cat
Dual Knock off Magnaflow Mufflers
LOL, i remember being a kid sticking potatoes in tailpipes, thought it was hilarious. I honestly dont remember ever having a lose of power when i got my cat cut off in a parking lot, it was just unbelievably loud but not a bad sounding loud IIRC. I had the guy set up the exhaust for cat-back system after that so i might just unbolt the damn thing and piss the neighboros off again.
I can always wear earplugs:lol:
