moving the radiator fans
ok first off i removed my ac so that radiator is gone so i have more open room in front of my normal radiator and was wondering if i where to change the polarity of the fans so that they blow air on the radiator instead of pulling the hot air away would i be able to place the fans infront of it between the bumper and radiator so it opens up more room in the motor bay or would that not work...sry if confusing
it could work, however pusher fans are less efficient.
why would you need to move them around? exhaust?
yea i want to make some headers for it and i want my intake on the passenger side so i want the pipe as far away from the exhaust as i can
I would think that the intake tube being longer would be less beneficial to you since you have to run it to the drivers side anyways... But I remember reading about Intrigue 3.5L fans are much skinnier than the other fans... Worth checking into IMO
