jake91 Posted March 4, 2012 Report Posted March 4, 2012 i know there is a thread on this somewhere but im having trouble finding it. this past week i have been having trouble getting my key out of the ignition, and ihave to run my shifter through the gears a couple times to get it to release the key. any sugestions. its getting kinda annoying lol Quote
WhatTheFehl Posted March 4, 2012 Report Posted March 4, 2012 http://lmgtfy.com/?q=grand+prix+key+stuck+in+ignition Basically, just use a paperclip or a screw driver and tap the release button through the access hole on the bottom of the column. There is even a passage about it in your owner's manual. Quote
jake91 Posted March 4, 2012 Author Report Posted March 4, 2012 (edited) lol mabey i should search more than w-body edit: im looking for a permanent fix not just a way to get the key out Edited March 4, 2012 by jake91 Quote
RobertISaar Posted March 4, 2012 Report Posted March 4, 2012 anthony has mentioned it a few times. i want to say a solenoid (BTSI?) needs bypassed. Quote
AL Posted March 4, 2012 Report Posted March 4, 2012 I have seen the shifter knob not return to its home position and if you are holding the button down, you cant get your key out, so it thinks your holding down the button Quote
runt Posted March 4, 2012 Report Posted March 4, 2012 Take the shround off of the column. You will see a white solinoid. On the bottom of it there will be a silver button. You can either zip tie the button in the "up/depressed" position or I think you can also unplug it. The only bad thing is you can remove the key in any gear but oh well. Sent from my iPod touch using Tapatalk Quote
Ramblin Garage Posted March 4, 2012 Report Posted March 4, 2012 have you been making sure the wheels are straight? not sure if this is the issue with a grand prix but when I had my truck if the wheel was turned too much the key wouldn't come out Quote
carkhz316 Posted March 4, 2012 Report Posted March 4, 2012 Take the shround off of the column. You will see a white solinoid. On the bottom of it there will be a silver button. You can either zip tie the button in the "up/depressed" position or I think you can also unplug it. The only bad thing is you can remove the key in any gear but oh well. Sent from my iPod touch using Tapatalk One can simply remove the the solenoid as well. I did this on my brother's GF's '01 GP Quote
runt Posted March 4, 2012 Report Posted March 4, 2012 I wasn't sure if you could just remove the solenoid or not so I didn't mention that. So if it can be removed, you could also just unplug it if ya didn't want to remove it. Quote
carkhz316 Posted March 5, 2012 Report Posted March 5, 2012 No, this is not the case. The solenoid is energized when the shifter is in park and the key is in the run ignition. If the solenoid is unplugged, or not working, it will prohibit the key from turning to the off position, so unfortunately, unplugging it will not solve the issue. Zip-tying the plunger will work, though. Quote
jake91 Posted March 5, 2012 Author Report Posted March 5, 2012 have you been making sure the wheels are straight? not sure if this is the issue with a grand prix but when I had my truck if the wheel was turned too much the key wouldn't come out i always have me wheels strait when parked its a little ocd thing i have lol Quote
jake91 Posted March 5, 2012 Author Report Posted March 5, 2012 The only bad thing is you can remove the key in any gear but oh well. Sent from my iPod touch using Tapatalk i think im smart enough lol thanks for the info guys i will just keep a screw driver in the car for now as it only does it 25% of the time and if it gets worse i will just zip tie it Quote
runt Posted March 5, 2012 Report Posted March 5, 2012 Yeah I had that problem for YEARS and never did anything about it till I went to sell it. My wife hated driving my GP because the keys got stuck. Quote
