emb1230 Posted February 29, 2012 Report Posted February 29, 2012 Just like the title say, getting a really annoying buzzing sound from the radio. I just discovered today, that I only hear it when the car is running. Any idea what that could be, and/or how to get rid of it? Quote
slick Posted March 2, 2012 Report Posted March 2, 2012 Increase/decrease of pitch with engine rpm? Quote
emb1230 Posted March 2, 2012 Author Report Posted March 2, 2012 Increase/decrease of pitch with engine rpm? no Quote
gp1991 Posted March 3, 2012 Report Posted March 3, 2012 The only experience i have had with this problem included increase and decrease of pitch. something inside of the radio must not have been wired correctly because when i got a new one from the junk yard, there was no more buzzing sound. i did open up the radio but found nothing that looked out of place. If anything you could try to go get a new old radio at the yard, relatively cheap. Quote
Jprice90 Posted March 6, 2012 Report Posted March 6, 2012 when i had my amp hooked up for the first time it did this, only because my one set of imputs were bad on it, just change your headunit or anything? Quote
emb1230 Posted March 9, 2012 Author Report Posted March 9, 2012 (edited) Yes, I had to replace the radio/control "pod" because the volume button was so worn out that "up" side did not work anymore. It buzzed with both the original pod and this new(er) pod. Edited March 9, 2012 by emb1230 Quote
Addicted2bass Posted March 9, 2012 Report Posted March 9, 2012 Does it buzz on just the radio or tape/cd as well? Quote
custom_90lumina Posted March 15, 2012 Report Posted March 15, 2012 sounds like a ground loop and you are picking up interference from the motor try replacing the ground on your head unit and all your speakers should fix it Quote
drew45u Posted April 22, 2012 Report Posted April 22, 2012 sounds like a ground loop and you are picking up interference from the motor try replacing the ground on your head unit and all your speakers should fix it Think you nailed it, exactly what it sounds like. Quote
