imabadczech Posted February 24, 2012 Report Posted February 24, 2012 I need some help, PLEASE. I just bought a 1 owner 97 cs sl with 93 k miles. I wanted to replace the hub assemblys in the front. I ordered the items and after I got the wheel off car, I realized the ones that were sent to me were incorrect. The wrong ones had a triangular back with holes for 3 bolts. My car currently has a 4 bolt assembly. So now I am confused. The 3 hole assembly part has the abs plug and the one I believe is the correct one for me (513044) does not show any plug in at all for the abs, which I was told was standard, So if I have abs, where the heck is the connection on the correct wheel hub? If anyone can please help, I sure do appreciate that! Craig in Marietta, GA Quote
Mel87 Posted February 24, 2012 Report Posted February 24, 2012 (edited) Only thing I can guess is they sent you one for a 1997 Cutlass, and not a 1997 Cutlass Supreme, which are two completely different cars. Edited February 24, 2012 by Mel87 Quote
55trucker Posted February 24, 2012 Report Posted February 24, 2012 (edited) There are two designs for the front hub assembly, 1st gen either ABS or non ABS (square 4 bolt mounting flange), the newer gen 2 design mounts with a three bolt triangular flange & the ABS connector is on the end of a short lead. If your vehicle is ABS equipped there is a reluctor ring on the outer end of the axle shaft that the ABS pickup aligns with to sense the wheel rotation. *need to speak to a mod with regards to the minor problem I have here with my browser constantly failing* Edited February 24, 2012 by 55trucker Quote
