emb1230 Posted February 12, 2012 Report Posted February 12, 2012 (edited) When you guys do an L67 swap, what do you usually go for? Series 1, 2 or whatever you can find? Also, this may also be a dumb question, but has anyone ever put an intercooler on one? Edited February 12, 2012 by emb1230 Quote
AL Posted February 12, 2012 Report Posted February 12, 2012 The L67 is the Series 2 3800SC, I dont think anyone has gone for a Series 1 3800 swap, the L32 is the Series III SC swap Quote
WhatTheFehl Posted February 12, 2012 Report Posted February 12, 2012 The series I supercharged 3800 is also called the L67. Quote
AL Posted February 12, 2012 Report Posted February 12, 2012 I just looked it up, Your right, didnt know that Quote
Andrew Posted February 12, 2012 Report Posted February 12, 2012 When you guys do an L67 swap, what do you usually go for? Series 1, 2 or whatever you can find? Also, this may also be a dumb question, but has anyone ever put an intercooler on one? Series 2 is by far the most popular, easiest, and has a large aftermarket. Yes there are several intercoolers available. Quote
95 vert Posted February 12, 2012 Report Posted February 12, 2012 Got a buddy of mine that I did a L67 swap on a 96 Cutty coupe for him a while back. I'll be putting a ZZP short stack intercooler, 1.9 rockers, and a 3.25 pulley on it here in the next couple of weeks. I'll let you know how it goes. Quote
BXX Posted February 12, 2012 Report Posted February 12, 2012 Just use a 98-03 L67. I did a swap for xtremerevolution using a L67 from a 00 Regal GS, and the 4T65e came from a 03 Century and I upgraded the diff to HD from a 99 GTP and ended up with 3.29 (IIRC) final drive. If your swapping into a Gen 1 W-body, you want most of the parts and wiring harness from a 98-99 Lumina/MC with the L36. FYI, PCM must follow the trans year for ease of sanity. IIRC they made changes in 02 or 03, so a early PCM wont work, throws it into limp mode. Use a L67 PCM, don't mess around with tuning the L36 unit. Just makes life easier Quote
pshojo Posted February 24, 2012 Report Posted February 24, 2012 I am in process of doing L26 swap. Similar to what 95 Vert has done. This is going in my daily driver, basically doing economy swap. So i don't have to mess with the trans mission. Quote
jeremy Posted February 24, 2012 Report Posted February 24, 2012 . So i don't have to mess with the trans mission. Until it blows up.... Quote
