fuel pressure at wot?
I had a low tank and while idleing heard my fp make a bit of a howling noise. It is OE with 238k miles. I put gas in and no more sound , but have noticed full throttle is a bit weak. I tested pressure at idle..it is around 35 line off. I need to test drive at wot and get a reading, what do yall think it should be?
Thanks
ps- its a 1994 regal 3.8
You dont test pressure at WOT
FUEL PRESSURE:
[TABLE=width: 100%]
[TR]
[TD]Ignition ON Engine OFF[/TD]
[TD]40.5 to 47.0 psi[/TD]
[/TR]
[/TABLE]
FUEL PRESSURE:
[TABLE=width: 100%]
[TR]
[/TD]
[/TD]
[/TR]
[/TABLE]
I wanted to to see if it sags under full demand...but, Im shy of the spec range you give , so ill go by that and r/r the pump. The tester i have does have a bleed line and when its opened the pressure drops alot, but there's nothing to compare it to.
thanks for the spec.
