radray64 Posted January 27, 2012 Report Posted January 27, 2012 you have a starting or running problem and suspect a fuel problem, I suggest changing the Injector O-Rings, Ive done this and well worth the ten dollars I spent not to mention the gas mileage you get back! Anyone Have any input to this? Quote
Schurkey Posted January 27, 2012 Report Posted January 27, 2012 you have a starting or running problem and suspect a fuel problem, I suggest changing the Injector O-Rings, Ive done this and well worth the ten dollars I spent not to mention the gas mileage you get back! Anyone Have any input to this? Anything can go bad. Everything wears out eventually. That said...I haven't seen a lot of fuel injector O-rings wear out. They don't get that hot, they're not under much compression--and they don't seal against enormous pressure. So if changing the O-rings made a big difference for you...great. Hasn't been an issue for me. Quote
brake Posted January 27, 2012 Report Posted January 27, 2012 Just spray around your O rings with WD 40 or carb cleaner. If your idle changes, replace 'em. Quote
