PJB Posted October 24, 2003 Report Posted October 24, 2003 Whats involved in swapping subframes in a '97 Cutlass Supreme? What needs to be unbolted, etc? Is it a tough job to do? I think mine is bent (something definately is on the right side) so Im gonna swap it with the one from my parts car. Quote
gp90se Posted October 25, 2003 Report Posted October 25, 2003 pulling the engine with it, should be 4 15mm bolts on the bottom and there might be 2 18mm on the back near the steering rack. -Jeff Quote
Brian P Posted October 25, 2003 Report Posted October 25, 2003 tech manual or Haynes has the full procedure Quote
patgizz Posted October 25, 2003 Report Posted October 25, 2003 full procedure: support front of the car with stands just behind the rear mount points of the frame support engine and trans with a engine hoist unbolt engine and trans mounts, power steering lines, and any other lines attached to the frame. also unbolt the steering rack and unbolt the ball joints and use a fork to pop the control arms off them. support the frame with a jack and 2x4 longways. unbolt the 4 frame bolts bam. Quote
PJB Posted October 26, 2003 Author Report Posted October 26, 2003 full procedure: support front of the car with stands just behind the rear mount points of the frame support engine and trans with a engine hoist unbolt engine and trans mounts, power steering lines, and any other lines attached to the frame. also unbolt the steering rack and unbolt the ball joints and use a fork to pop the control arms off them. support the frame with a jack and 2x4 longways. unbolt the 4 frame bolts bam. Thanks. Thats how the one we just did in a Sunfire came out but I wasnt sure if mine was the same. Luckily my friend has a lift to do the swap. BTW, the motor isnt coming out. Quote
