No constant power
Went to start my car and no radio. Pulled the radio out and checked connections. I get keyed power but no constant power. Swapped the radio fuse for a known good one and no change. What now?
Does the radio work when you hook it up directly to the battery?
I haven't checked the radio, but I'm getting no constant power at the car harness at all. I seem to recall a car that had the same issue that the radio circuit was tied in with something else that that fuse blew, but I don't know if that's the case or what fuse it would be.
Worst case I guess I run my own hot wire, but I don't feel like doing that right now.
Who knows what happened. Just run a new wire through I guess. Not a whole lot else you can do.
For future reference for others, the I/P ELECTRONICS BATTERY FEED fuse runs the circuit for the radio memory. It also runs the chimes, which I had disconnected.
