93 lumina z34 code 32 egr valve
is there a easy way to clean out the egr valve to fix the code problem ive watched videos on youtube of people just cleaning them out with carb and choke cleaner is that the correct method just wondering?
Just take the valve off and start cleaning it. There isn't really any trick. How do you know it just needs cleaned? It's probably bad.
Mind did this, and I think Nunzi's did this as well. I tried cleaning it, and ended up swapping another plenum over after some Nunzi advice and it went out. The LQ1 is a PITA to clean that and from what ive seen it goes up and back down again, making that passage hard as crap to fully clean.
