Time Belt Replacement?
I have a 1997 lumina with only 81,000 miles on it, i never looked at or replaced the timing belt. When is a good interval to start considering replacing the TIMING belt?
If you have the DOHC GM recommends belt replacement every 60,000 miles or 100,000kms. So I'd say that you are past the point in considering a possible replacement.
I do believe the 96-97 belts had a longer replacement interval.
They are a totally different belt, with more rounded teeth.
Ok I will look at that link.
I thought for my 97 it was atleast 100K miles, I didnt know I was already past the interval.
I just dont want to dish out cash and pry apart the engine when I dont have to.
Any symptoms of dying timing belt? or do they just snap and cause engine damage?
Theres an inspection cover you can take off and look at, If the belt looks worn (fraying, shredding, things like that) Then it needs replaced much sooner than later
They don't necessarily *snap*. What happens more often than not is the teeth shear off, and you won't necessarily see this, and the portion where the teeth have sheared off enough cause problems is when that section passes under the drive sprocket on the end of the intermediate shaft. Without warning, the belt stops dead in it's tracks, the cams stop (the crank doesn't) and then (in the case of the interference engine) you now have boat load of headache you didn't bargain for.:(
As Al stated, pull off the inspection cover on the nose end of the front cam gallery and have a look in there to see what sort of mess is laying in there.
One needs to bump the engine over several times to get a look at the belt's condition all thru it's length (disconnect the harness to the Ignition Coil pack so the engine does not fire), and take what steps are necessary to preserve your engine.
