Mel87 Posted January 8, 2012 Report Posted January 8, 2012 I don't know why but I like the look of slow blinkers, mine blinks fast, is there a way to reduce the flash rate? Quote
jake91 Posted January 8, 2012 Report Posted January 8, 2012 drain about 7oz of blinkerfluid and you should be all good sorry couldnt resist. hopefully someone who isnt an asshole will post up soon Quote
ScoobyDoo82 Posted January 8, 2012 Report Posted January 8, 2012 I dont think your Cutlass has an electronic flasher, and unless it does, just go to the junkyard and pull a ton of flashers out of cars and pop them in until you get one you like. Quote
Z34guy Posted January 8, 2012 Report Posted January 8, 2012 This reminds me of the scene in "Cars" when Filmore and Sarge are watching the blinking yellow traffic light and Filmore says "I'm telling you. Every third blink is slower!". Sarge replies with "The 60's weren't good to you, were they?" Quote
94 olds vert Posted January 8, 2012 Report Posted January 8, 2012 Like Spencer said, try a bunch of different flashers. I also don't like fast blinkers either. Quote
ScoobyDoo82 Posted January 8, 2012 Report Posted January 8, 2012 Im not sure if Fords use the same flasher, but I noticed a majority of older Fords have a slow blink, couldn't hurt to check. Quote
white4d96 Posted January 8, 2012 Report Posted January 8, 2012 Could make a 555 timer with a variable resistor, then splice it in as your flasher. Then just adjust your resistor until you get your desired effect. Quote
tornado_735 Posted January 8, 2012 Report Posted January 8, 2012 I can't stand slow turn signals...but for the record, most early W's (especially Luminas) seem to have flashers that get old and blink slowly. I replaced mine with a hazard light flasher (can't remember the numbers). Quote
