dashboard disassembly
I need to replace some of the bulbs in my instrument cluster - How much of a chore is it to tear it down far enough to replace them? Is there a write up on it somewhere by any chance? the search function doesnt seem to like me
Put the column in the lowest tilt position. Pop the trim off around the cluster/radio(snaps in). There are 2 7mm(9/32) bolts holding the cluster, the bottom of the cluster tabs in, and one electrical connector on the right lower corner of the cluster. You should be able to tilt the top of the cluster towards you and remove around the steering column.
Getting a cluster out is incredibly simple. I've done it so many times I could do it with my eyes closed! Obviously, be careful with the tabs not to break those, but that's about it.
It's that easy?! Jesus. I figured it was a big song and dance.
thanks guys.
