So i have a 94 cutlass supreme. bought it 2 weeks ago for $500 body is 100% perfect no rust no paint fade no dents nothing spotless but the engine on the other hand recently started a rod knock its the 3.1L so i picked up a 3.4L to swap it out with but i was wondering do i need a different key now? since the keys have that chip inside? or what?
by 3.4 I assume you are talking 3400? no you don't in fact with some small exceptions a 3400 is a bolt in replacement for the 3100.
im new to the whole gm deal ha ive always had a dodge. but its the 3.4 that came in the supremes yeah.
There are 2 different 3.4s GM used over the years the 3400 Pushrod and the 3.4 DOHC which are you using?
The key code on the chip is not directly related to anything under the hood... the module it activates is in the dash. changing the computer or anything else under the hood will not be affected by what you are doing..
HOWEVER.... you need to know the direction of what you are doing under the hood. if you are using a 3.4 dual over head cam engine, you need to make sure you have the wiring and computer that goes with it for it to even run in your car. it will not run properly in the least if you just wire it into the car's stock computer. Ideally a 94 or 95 only motor and all accesories, wiring and computer should be swapped in completely. any thing else (such as a 91-93 motor) will require much more work...
That said, you need to be very clear on what you are doing it you need help to make this work or do not know what you are doing.............
If it was from a supreme then he's in trouble.
No it came from a pontiac
