RUNDLC Posted January 3, 2012 Report Posted January 3, 2012 Can someone tell me what happens if I get a code 33? It a 91 3.4L DOHC Car starts and idles but really has no power, this is now the only code I have. The only thing I can thing of now to make it run this poorly is cam timing??? ANY HELP APRECIATED TIA Quote
AL Posted January 3, 2012 Report Posted January 3, 2012 You need a Map sensor, its on the passenger side on the intake with a green connector Quote
RUNDLC Posted January 3, 2012 Author Report Posted January 3, 2012 Ok Thanks for that, but what I would like to know is how it will make the car act? Will it lack power? will it idle rough? What symptoms will I see from the motor? Quote
AL Posted January 3, 2012 Report Posted January 3, 2012 The symptoms you posted sound exactly like a map sensor, in fact to test the sensor, unplug it and see how it acts, if it acts the same then you are looking at another issue Quote
RUNDLC Posted January 3, 2012 Author Report Posted January 3, 2012 Ok Thanks Al I will unplug the sensor and see what happens. If that is my issue I will be one happy camper!! Quote
