paulo57509 Posted January 2, 2012 Report Posted January 2, 2012 Has anyone else noticed that CA has lowered the max allowable limits in the past year or so? Check the numbers between 2007 and 2011 (2007 is the same as 2009). I would have passed (barely) if the state didn't screw with the numbers. Quote
1990lumina Posted January 7, 2012 Report Posted January 7, 2012 Check that the EGR is functioning properly Quote
19Cutlass94 Posted January 7, 2012 Report Posted January 7, 2012 Move out of CA. Problem solved Also check any EGR passages as well. Quote
ManicMechanic Posted January 7, 2012 Report Posted January 7, 2012 Has anyone else noticed that CA has lowered the max allowable limits in the past year or so? Freakin' Texas has done it too...Damn commies. Quote
55trucker Posted January 7, 2012 Report Posted January 7, 2012 Has anyone else noticed that CA has lowered the max allowable limits in the past year or so? Check the numbers between 2007 and 2011 (2007 is the same as 2009). I would have passed (barely) if the state didn't screw with the numbers. You sound surprised that Ca has tightened up their emission regs...again. Seems that every time it happens there, our premier here likes to play *monkey see, monkey do* or....*if it's good enough for Cali then it's good enough for us*. What was the limit before the drop to 545? Ours here is 630ppm. http://www.smogtips.com/failed-high-NO-nitrous-oxide.cfm Quote
xtremerevolution Posted January 8, 2012 Report Posted January 8, 2012 Move out of CA. Problem solved That's what I did. Here in illinois, my 1995 Regal doesn't even have to get tested. Sent from my HTC Awesome using Tapatalk Quote
