DOHC valve size?
what are the valve sizes?
I'm running simulations in desktop dyno
marcus
according to my Haynes manual... 0.370 for both....
at the time I didn't know what they were... so they stayed at .350
or 5 buxs PayPal and ill send you a CDR wit it in there plus some mp3 (music) of your choice :-D
I will give you 5 bucks tell me where to send it.
EDIT: will it work on windows 98/xp? i have two comps one with 98 and one with xp. anything else i should know for it to work before i buy?
if the computer only has win 98, it is probly a way slow computer anyway, so id only run it on the one with xp.
uh. .370" for the valve sizes eh. What a POS engine!
Seriously, here are the CORRECT specs to use in DD2k. I used some incorrect specs to come up with the 13 degree exhaust retard...and it works like it should in real life according to that. With the correct specs it shows nothing much at all. Anyway....
Bore = 3.620
Stroke = 3.31
Intake Valve = 1.436"
Exhaust Valve = 1.258"
Compression 9.25 (9.5 for manuals, 9.7 for 96/97 engines)
Inductions...just guesses, 600 CFM, tunnel ram manifold. Sequential fire gives closer to stock specs though but the tunnel ram is what we use for the pushrods to get them closer to spec stats.
Exhaust, stock manifolds and mufflers
Cam: Stock street/economy
Lifter: Hyd
Cam Specs @ 0.050 lift
Int lift = .370
Exh lift = .370
IVO: -1.5
IVC: 42.5
EVO: 45.0
EVC: 3.0
http://60degreev6.com/download/DD2K/
I dont think the .flw file is accurate either, so I used the flowbench pic from DKOVs heads to make my own. The .dyn file there is the one I used that is incorrect.
For the CFM, I found this Equation a long time ago, telling how to figure CFM. Take the max rpm for the motor, multiply it by the cubic inch displacement, then take that number and divide by 3456. So for the DOHC:
7000*204.4= 1430800
1430800/3456= 414.0
Yes, but I think that number isn't what the engine needs, but rather what the intake can flow. That program doesn't even know runner length or volume. Its good to play around with but thats about it.
Yeah, that makes sense. It does need a place for intake runner length, and volume that would make it A LOT more accurate.
